I have Power Bi Desktop version.
Will upgrade to Power Bi Pro.
Any tutorial on how to share Reports in Power Bi Pro.
I have 200 Tabs in my Desktop file, need to share same with 9 email IDs for whom will buy Poer Bi Pro Licenses.
Hope you are doing well.
the solution is you can provide the member access to them so they will be able to download /access all file from power bi services.
The only condition is all email id should be in same azure active directory.
Let me know in case any further discussion.
I can see you have published your report in my workspace that is not for collaboration.
you have to create different workspace for collaboration purpose.
Then access tab will be visible there you can provide and access to your team.
just following up if the response above help you solve your inquiry?
We’ve noticed that no response was received from you on the post above. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Due to inactivity, a response on this post has been tagged as “Solution”.
