Hi All,
Is there any possibility to get a matrix visualization of the below format -
In the screen shot the measures are in columns and then the dimension get broken down accordingly
Hi All,
This should be pretty easy to accomplish. Trying putting this together yourself inside a PBIX file, and if you run into an issue post it here in the forum so we can better assist.
Hi ,
All I was able to achieve this.
