I’m looking to demo/present on how to use/navigate/filter a report within Power BI Service and wanted to make sure I cover all the basics. Is there resources that primarily focus on end-user? User guides?
Hi @voodipbi, was the video suggested by @baymaxx help in your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @voodipbi, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
