There is a table visual in the page.
The filter on the right side of the page is for the page which shows the columns which I can filter…
If I have multiple filters selected, then is there a way to clear all the filters in one go rather than clearing each column filter?
thank you
Hi @arkiboys,
you have 2 main approaches for that:
via bookmark - more info you can find at:
https://radacad.com/clear-all-slicers-in-power-bi-a-bookmark-story -
via buttons
If you have different slicers filter → there is Button-> Clear all slicers options.
(be aware that you in PowerBI Desktop before publishing you need to hold CRTL + click to work)
Hope it helps.
Hello,I spoted the clear button .
I select a number of filters on the page (Filters on the right hand side of the page) and then I click+ctrl on the clear button but filters are still there selected
Clear all slicers works only for slicer filters.
If you have other type - you can use first approach - via bookmarks. You have basic instruction on the link above.
