Hello,
We have a requirement of developing power bi reports and then embedding them into an application. While doing that, we need to check the user logged into the application and as per his access, we need to filter the data present in that embedded reports. Can you please clarify my questions here.
- What kind of Power BI license do we need to embed reports into external application?
- How to embed reports? Using workspace or apps?
- How to use application user roles to be given to power bi embedded reports?
Kindly help. Thanks in advance.
I think you need to have Embed SKU which are A or EM Skus and also need a Power BI Pro license to publish reports into this service.
With Embed (Rest API), you can embed dashboard/report/or a even single visual.
Hi @Avenkataanusha, did the response provided by @amira.bedhiafi.pro help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
Hi @Avenkataanusha we’ve noticed that no response has been received from you since the 20th of January. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Hello @Avenkataanusha
Please refer this video about embed Power BI report in another application.
https://www.youtube.com/watch?v=z6kFtJVhgjQ
