Hi All,
Was wondering if anyone was aware of any websites using Power BI embed.
I am looking for examples of embedded Power BI within an application or webpage.
Any references would be appreciated.
Regards,
Haroon
Hi All,
Regards,
Haroon
Hi @haroonali1000. I’ve not had access to nor explored embedded, but I did run across Microsoft’s Embedded Playground a while ago:
https://microsoft.github.io/PowerBI-JavaScript/demo/v2-demo/index.html
I imagine you’re aware of this site, but if not, hope it helps.
Thanks @Greg.
Yes this is something I am playing about with at the moment.
Working with a client looking to white label power bi was wondering if anyone had any good examples.
Appreciate the response.
Haroon
Hey Haroon,
we use embedded to allow clients to access reports, just a simple portal, happy to give you a peak just pm me
Cheers
Mark
Thanks @melgar. Very kind of you.
Client has actually decided to hold off for now.
But I will hopefully keep you offer up my sleeve.
Thanks,
Haroon
