I have a problem of running out of space in C: drive , I solved the problem temporary by un-installing and Installing power bi in Drive (E:) that have larger volume with enough spase but the problem still not sure , I found 2 Folders in C: drive here is the complete path of them:
C:\Users\pc\AppData\Local\Temp (300 MB)
C:\Users\pc\AppData\Local\Microsoft (55 GB)
I need to move the cash or those power bi on (c) subfoders into E: drive but I’m not sure is this will cause a problems for Power bi desktop or not ? Is there a way in Power bi setting to store the cash in another drive or folder (E: in my case)?
I’m not able to do Analyse because the key is disabled may be because I have to run it as Admin?
how I run control pannel as admin?
Also you didn’t answer on my previous question shall I move the C:\ Power bi cash safely to (E:) drive?
Also I re-install power bi desktop from (c:) to (E:) is that means previous archive of power bi safely can move (delete) to (E:)?
Is their a way to setup the cash of power bi to (E:) drive other than c: drive?
The folder : C:\Users\pc\AppData\Local\Microsoft\Power BI Desktop\TempSaves
Have big Temporary files we can remove it or at least backed it up somewhere .
Power BI stores support/temp/cache files locally under the user’s Local profile. I am a light user of Power BI and I have a relatively large amount of junk in the directory shown below. For users of the hosted service and desktop IDE, the “Power BI Desktop” folder just above the “SSRS” one has the same folder structure. The \TempSaves folder is also where those auto-recovery files end up which you occasionally see messages about in the desktop when opening a report.
If you clean out the cache, trace, and temp save files occasionally, it should address your issue.
Hi @MAAbdullah47, did the response provided by the users and experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @MAAbdullah47, we’ve noticed that no response has been received from you since July 2nd.
