Power BI Desktop - Publishing Prompt
Good afternoon:
I have been working on a few updates to a BI dashboard that references a certified data set within my organization. When I publish it to the Cloud, I received a prompt that I have not seen before (see attached). Admittedly, I am not familiar enough to understand what this is telling me.
Has anyone else run into this? If so, can you explain to me in layman’s terms what it means and how it could impact the published dashboard?
I appreciate your consideration on this!
Hi @Rob_Tanner - Please refer to below Microsoft community link where people are facing similar issue and discussing possible solutions.
It seems there was a feature earlier that allows to create Calculated Column/table from published Dataset that Microsoft has removed now.
Ankit J
I appreciate the clarification!
