Hello,
I have created flow to send an automated email with Power bi dataset attached, the problem I am facing is that dataset extract has table name as a prefix with every column name, the format appears like this on every column : table_name[col_name] also the order of the columns is not same as power bi table visual, please find the below code used for BI step. Appreciate your help on resolving this.
DEFINE
VAR __DS0Core =
SUMMARIZE(
‘proc_call’,
‘proc_call’[Index],
‘proc_call’[pack_id],
‘proc_call’[pack_number],
‘proc_call’[pack_number_shift_no]
EVALUATE
__DS0Core
ORDER BY
