Is there a way to monitor dataflow refresh history and status for all workspaces?
I have seen solutions for a single dataflow but this is not scalable when you have hundreds.
Is there something available or planned that addresses this?
If you are the Power BI Administrator and Capacity administrator, you can leverage powershell script or Power Automate flows in conjunction with REST API to get the refresh history of all workspaces.
Hi @jay89, did the response provided by @pranamg help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @jay89, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
