Power BI - Can I keep the original filter criteria after table interaction
I know my question is crazy, but I just wonder to know if it is possible or any workaround on it.
My model will show Sales Amt in HKD or in local currency with below logic checking:
  1. If multiple currency (multiple RSO is involved) , sales $ will display in HKD
  2. if only single currency (RSO using same currency), sales $ will display in local currency.
    (Using Calculated + distinct count+ allselected).
However, in my sales person comparison tab, I get two tables, 1) Sales by RSO (sales person), 2) Sales by Product Type
By default, as no RSO or no sales person is selected, both table will show in HKD.
But when I select any sales person in the first table, as it become filtering the RSO and sale person, my second table will show sales in local currency, logically it is correct, but it is very confusing as first table still show sales in HKD, but second one is show in local currency.
Is it possible to have a DAX to keep second table show in HKD unless RSO has been selected in filter panel first?
I just search it is no way to make my first table show in Local currency immediately after I click on it.Sales Detail Report - Europe - Copy (2).pbix (3.9 MB)
Hi @chiu2003, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Some images would be helpful. So we can see exactly the scenario you’re describing.
Hi @chiu2003, we’ve noticed that no response has been received from you since the 30th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
