Power BI bug - Black Filter Pane & Table
I tried opening the ‘Advanced Scenario Analysis Techniques For Power BI with Dax’ file via the video training section and I’m getting this buggy file. The filter pane is showing black and when I create a table the table is black as well. Can someone advise?
Hello @YusufGillani,
Well actually is not a buggy file. The formatting which was incorporated in that file contained the “Black Theme” format. Below is the screenshot provided for the reference -
You can change the theme in your PBIX and you shall have the proper colors in your filter pane.
Hoping this helps you. :slightly_smiling_face:
Thanks and Warm Regards,
Harsh
