We have a prospective customer who have very large data sets that increase significantly on a minute by minute basis getting information from 100,000+ sources.
Clearly we would have to use Direct Query linking to a SQL database on an Amazon AWS server but I just wonder if Power BI itself is the correct data analysis tool to be using in this particular environment.
HI @PaulBoyes , while waiting for other members to jump in, I suggest using the forum search to discover if your query has been asked before by another member. Thanks!
Hi @PaulBoyes - If data is cleansed and Harmonized, meaning data is already integrated into 1-2 Facts tables from different sources instead of individual files from multiple Sources then yes Power BI can be considered as a Tool for reporting.
With Direct Query, there will be performance issues though with other limitations that are readily available on internet.
Hi @PaulBoyes, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can reopen this thread.
