Power BI and Azure DevOps ALM KPI and connectivity
Hi Everone,
Looking to seek advice or possible help for a Power BI sample report or may be a good direction on connecting with Azure DevOps project management tool.
What are the different KPI’s we could map and of course any sample work is welcome.
Any help or direction is appreciated.
Thanks,
SJ
@sanjeevnaidu,
Welcome to the forum - great to have you here!
Here are a few links re: developing KPI-type reports for ADO using Power BI that you may find helpful:
https://docs.microsoft.com/en-us/azure/devops/report/powerbi/create-quick-report?view=azure-devops
https://docs.microsoft.com/en-us/azure/devops/report/powerbi/active-bugs-sample-report?view=azure-devops#create-a-daily-bug-trend-report
https://docs.microsoft.com/en-us/azure/devops/report/powerbi/active-bugs-sample-report?view=azure-devops#create-a-card-for-latest-bug-count
The last link also has a live sample report (screenshot below)
Hi @sanjeevnaidu, we’ve noticed that no response has been received from you since the 9th of October. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
