In this workout, you are going to create a flow that will capture 3 different UI elements within the Enterprise DNA Forum, and then you will need to rename each UI element withing Power Automate Desktop.
Here are the steps that should be used to complete this flow:
When posting your solution, please make sure to blur out your results of what the Main tab looks like. There is no wrong answer on what you rename the UI Elements, but just make sure you choose something that best describes each element.
This was challenging one for me as I couldn’t this UI Element. I was getting errors after creating creating the flow. I finally figured it out viewing some youtube videos.
Here is my solution. I used the Click UI element in window for each of the steps to capture a UI element. I then clicked on the 3 black dots, and renamed each UI element.
