I am currently working through the power apps EDNA course and am running into an issue comparing a text value and control value. I need help reformatting either the text value to control, or vice versa. Does anyone have any suggestions? Thank you in advance!
The VIPLevel cannot be compared to your dropdown as your VIPLevel is text and Dropdown is numeric. Did you try to re-format the column type within Excel from string to number, or use the Value() function to convert it?
Hi @nickjordan32, we’ve noticed that no response has been received from you since the June 29 of June. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @nickjordan32, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
