Anyone familiar with the POWER BI REST API, more importantly, adding rows to datasets using rest api (method: PostRowsInGroup)?
Regards,
Christopher
Regards,
Christopher
Hi @Wlknsn, we’ve noticed that no response has been received from you since the 11th of September. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
