Hi @corkemp,
You can try this. Just paste the code into a new blank query.
let
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("zZJva8IwEMa/SulrByb9k/alOtgmzAkVYYgvzjbMsJqONPr5l4tn7Wo/wMCj5nfX57lLb7cLZyVU8qTK4FOCCSdhYc+V1DZ4e3aHFZyke2xka4MNfEvtDh8XaaCu3b/ut21KOASFLK1qdD/xDvbY3hJtP7NqdLCV5gD143v7yS7s1xYWdAWmCoqyMdjP3J2JK41gLU3pmla1/F/lOAmfcvbEuUswFy+yMV9YNavgx6qLDPByMRlNkbpIXeRYy/gNCRdZ4lFEKHeReFUeE8JUngxMMdZwrscsfcGc3vTyUUYk6+RZSii+o5gQdhmLgSOKLZujHnNkqLtwgZOJuLNckCUT3dwLmlukviomhJZJNLDEZAEGjqNTotorqXkxxohgq2nu9QWh++1HOSF27eKvJV7XUratKmH0a2JLG2otv7qKHsr8oFFKiN2vgxPCZ84Hrli/PNdq1JPd1sXvhp+B8d5uDNbFf/BrZ/2lyuJwv/8F", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Column2 = _t, Column3 = _t, Column4 = _t, Column5 = _t, Column6 = _t, Column7 = _t, Column8 = _t, Column9 = _t, Column10 = _t, Column11 = _t, Column12 = _t, Column13 = _t, Column14 = _t, Column15 = _t, Column16 = _t, Column17 = _t, Column18 = _t, Column19 = _t, Column20 = _t]),
TransposeTable = Table.Transpose(Source),
ReplaceValue = Table.ReplaceValue(TransposeTable,"",null,Replacer.ReplaceValue,{"Column1"}),
FillDown = Table.FillDown(ReplaceValue,{"Column1"}),
MergeColumns = Table.CombineColumns(FillDown,{"Column1", "Column2"},Combiner.CombineTextByDelimiter("|", QuoteStyle.None),"Header"),
TransposeBack = Table.Transpose(MergeColumns),
PromoteHeader = Table.PromoteHeaders(TransposeBack, [PromoteAllScalars=true]),
AddTempCol = Table.AddColumn( PromoteHeader, "Temp|", each
List.Zip(
{ "Overall", "Vocab", "Maths", "Non-verbal" },
Record.ToList( Record.SelectFields( _, List.Select( Table.ColumnNames( PromoteHeader ), each Text.EndsWith( _, "Standard Score", Comparer.OrdinalIgnoreCase )))),
Record.ToList( Record.SelectFields( _, List.Select( Table.ColumnNames( PromoteHeader ), each Text.EndsWith( _, "Band", Comparer.OrdinalIgnoreCase )))),
Record.ToList( Record.SelectFields( _, List.Select( Table.ColumnNames( PromoteHeader ), each Text.EndsWith( _, "Stanine", Comparer.OrdinalIgnoreCase )))),
Record.ToList( Record.SelectFields( _, List.Select( Table.ColumnNames( PromoteHeader ), each Text.EndsWith( _, "Percentile", Comparer.OrdinalIgnoreCase ))))
NewTable = Table.ExpandListColumn( Table.SelectColumns( AddTempCol, List.Select( Table.ColumnNames( AddTempCol), each Text.EndsWith( _, "|" )) ), "Temp|" ),
ExtractValues = Table.TransformColumns(NewTable, {"Temp|", each Text.Combine(List.Transform(_, Text.From), "|"), type text}),
SplitColumn = Table.SplitColumn(ExtractValues, "Temp|", Splitter.SplitTextByDelimiter("|", QuoteStyle.Csv), {"CEM category", "Standardised Score", "Band", "Stanine", "Percentile"}),
ChType = Table.TransformColumnTypes(SplitColumn,{{"Standardised Score", Int64.Type}, {"Stanine", Int64.Type}, {"Percentile", Int64.Type}}),
RenameCols = Table.RenameColumns( ChType, List.Zip( { Table.ColumnNames(ChType), List.Transform( Table.ColumnNames(ChType), each Text.TrimEnd(_, "|")) } ))
in
RenameCols
I hope this is helpful.
