Pipedrive CRM Integration
Our organization recently started using Pipedrive as our main CRM tool. Has anyone been able to integrate Pipedrive into Power Bi or know how to do this?
This is unfortunately something I’m not familiar with and have never done. Hopefully someone else in the community and on the forum may have something to add here
Sorry not familiar with this either, just did a web search and that turned up these:
Hopefully there is something there that will help you get started. Also noticed that there are several third party solutions on the market…
Hi @jmolina, we’ve noticed that no response has been received from you since the 4th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Hey! It’s been a while since your post, but I wanted to offer some insight. Just dropping by to see if everything’s sorted with your Pipedrive CRM integration. If you’re still facing any hiccups, feel free to reach out. By the way, have you ever explored Sugar Customer Relationship Management? It’s another solid option worth checking out!
