Hi. I want to pin some my visuals but can seem to make the pin icon appear.
I already did go to Options > Report Settings > Made sure Hide the visual header in reading view is unticked.
Is the pin icon available in Power Bi Desktop at all?
If yes, can someone help make this icon show on top of every visual I have in PowerBI Desktop?
I’m using Version: 2.94.921.0
You need to go into settings for the visual, ensure the Visual Header is on, then scroll down to turn the Pin Icon on as per below. Republish your report with the new settings and the Pin Icon should appear. Then pin to the dashboard you want it to appear on
