Personal Or Enterprise Gateway
Which gateway should I choose for scheduled refresh of my excel data source in Shared drive.
Personal or Enterprise Gateway?
There are 4-5 users for the report. Need to be refreshed only once in a day,
What are the factors to be considered
Here is a great article by Reza Rad that explains both of them. After reading this you should be able make a decision on which is best for you.
What is meant by Sharing gateway in On-Premise mode?
Did not get the meaning of it.
Also should I install On Premise (Non-personal) ,on my system or with the help of admin in Server?
My laptop wont be ON all the time.
Hi Anu,
Since your laptop won’t be running at all times and probably uses a wireless network connection the better option would be to install the On-premises recommend gateway on the server.
Hi @Anu, we’ve noticed that no response has been received from you since December 31, 2019. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. You may reopen a new thread when the need arises. Thanks!
Thanks for the reply,Melissa
