RDW
September 29, 2021, 9:23pm
1
I’m calculating a percentage of total services and these DAX expressions give the intended result.
Services =
CALCULATE( DISTINCTCOUNT( ‘Journal Table’[ID Count] ), FILTER( ‘Journal Table’, ‘Journal Table’[Void Flag] <> “Y” || ‘Journal Table’[Journal Code] <> “A” || ‘Journal Table’[Journal Code] <> “C” || ‘Journal Table’[Journal Code] <> “E” || ‘Journal Table’[Journal Code] <> “P” || ‘Journal Table’[Journal Code] <> “U” ) )
Percent of Total =
VAR Denominator = CALCULATE( [Services], REMOVEFILTERS( ‘Journal Table’ ), SUMMARIZE( ‘Journal Table’, ‘Journal Table’[Unit ID], ‘Journal Table’[SubUnit ID], ‘Journal Table’[Journal Code], ‘Journal Table’[Void Flag] ), SUMMARIZE( ‘Date Table’, ‘Date Table’[MonthShortName] ))
DIVIDE( ‘Journal Measures’[Services], Denominator, 0 )
Is it possible to filter out Service ID 700 and still have the total equal 100%?
Percent of Total.pbix (2.9 MB)
Harsh
September 29, 2021, 10:10pm
2
Hello @RDW ,
To achieve the results of 100% at a grand total level. Just create a measure as provided below alongwith the screenshot of the final results provided for the reference -
Percent of Total - Harsh =
DIVIDE(
[Services] ,
CALCULATE( [Services] ,
ALLSELECTED( 'Journal Table'[Unit ID] ) ,
ALLSELECTED( 'Journal Table'[SubUnit ID] ) ,
ALLSELECTED( 'Journal Table'[Service ID] ) ) ,
0 )
Thanks and Warm Regards,
Harsh
Percent of Total - Harsh.pbix (2.9 MB)
RDW
September 29, 2021, 10:56pm
3
Hi @Harsh , it works perfectly. Thanks for your help!
Harsh
September 29, 2021, 10:58pm
4
Hello @RDW ,
You’re Welcome.
Harsh
