I did a video recently that dealt with a very similar question. The breakdown of that particular problem starts at around the 8:40 mark of the video below. If this doesn’t adequately address your question after watching it, please provide a PBIX in progress file, and I would be happy to work with you on a specific solution.
FYI – we have some great free tools available for the creation of mock datasets, in addition to the masking techniques for your actual data file. Check out the thread below which provides links to all of them:
Hi @WendyZhang did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @WendyZhang, we’ve noticed that no response has been received from you since the 14th of June. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @WendyZhang, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
