This is a bit generic question and use case that I am looking into. Dont need pbix file for that. So here is the situation:
We need to embed a Power BI report to the portal and want to test the use case where user passes : [account no] and [account name] from a web portal and we want Power BI report to get filtered with [account no] and [account name]. Is it possible in Power BI?
For Direct Query and Relational sources , can refer to below Microsoft Post where they have included option to pass values from Slicers to source. There are few limitations
For Import Mode, unfortunately there is no option to pass Parameter from Slicers. For Report Owners, What can be done is to create Power Query Parameters and use them to filter the source. Once published to service, they can be modified in Scheduled refresh section.
Hi @rit372002, did the response provided by @ankit help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @rit372002, we’ve noticed that no response has been received from you since July 2nd. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @rit372002, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
