Pass Parameters from Power BI to SAP Fiori
Hello,
Want to check couple of items from PBI Functionality perspective:
So once I display the data in a table , if i want to click on a cell and open a FIORI Application…is that possible? basically need to send the details.
For example : Lets say we display data for a region and then i need to pass the region to the FIORILINK and that will display all employee under that region…
Basically pass the parameter from Power BI report cell to open a parameterized link?
Thanks,
RK
Thank you for adding your question to the Community Forum. It would be prudent to post your question to the SAP Fiori Community Forum as they are able to contextualize your question in terms of Fiori for Design and Integration Guidelines and best practices.
