Has anyone used Snowflake SQL as a datasource for their Paginated report?
I am trying to do the cascading prompts and get the value from one query and putting it in the 2nd one but getting issue.
Here is more detail:
Here are the steps I have done:
- Data Source connection is : ODBC/Snowflake.
- First dataset: Simple SQL query to get “Parent” Info.
select RETAILER_NAME
from table where Enrollment_Year = 2022
- Second dataset: Simple SQL query where I am referencing the parameter. In this case, it is :Parent
select Program_Group_Name
from "table" where Enrollment_Year = 2022 and Retailer_Name = :Parent
I have Parameter here:
Defined it Here
Error:
Here is the RDL report for reference.
https://drive.google.com/file/d/1QFjCHQOdqUKIov_ST5iY6vf6RxlEkkNq/view?usp=sharing
TIA
-EZ
