Overall KPI Score based on multiple kpi's
I have a table 4 different KPI’s
Is there a way of adding a weighting to each one and then summing up to give an overall Score which in turn could be represented by RAG
Hi @AliB - It shall be possible using DAX. Please share PBIX file for Further help.
Ankit J
Hi @AliB, I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
  • A clear explanation of the problem you are experiencing
  • A mockup of the results you want to achieve
  • Your current work-in-progress PBIX file
  • Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Hi @AliB , we noticed that you have not responded to our request six days ago. We are waiting for the masked demo pbix file and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @AliB, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
