Wondering if anyone knows how to do the following?
Where i have an Order Value of say £500 split over 5 months - i would have a monthly value of £100.
How can i create a count of the number of instances that occur per order id Line - i .e. instalment 1, Instalment 2, instalment 3, instalment 4 instalment 5?
Here is another way of doing it in Power Query without having to use a calculated column. There is a great video on this technique. I’ll include the link below.
I’ve always done this in Power Query ala Jarrett’s solution, but I think your DAX solution is ingenious and I’ve posted it as a community entry in Analyst Hub (with attribution, of course).
A slightly different approach to your question. My actual use case was about having a fact table and a table with transportation costs, object was to distribute the costs evenly by weight split across the multiple items in one shipment. Example splitting costs dynamically.xlsx (19.6 KB)
Paul
Thanks for looking into this for me - much appreciated.
This appears to work, however it looks as though it is providing a value from 1 to xxxx for all order id’s rather than 1 to xxxx for that specific / unique ID.
Think i need to bolt on another filter somewhere in this.
