Please can someone point me in the right direction. I have two tables , table one shows current on hand balance , table two pulls in future manufacture orders. I can easily pull through manufacture data week by week and accumulate , what I need to do is use the OHB as the starting point then build on the rolling balance. Any idea how I do this ?
Thanks in advance.
Jeff
Hi @Jeffb
Sam Covers Cumulative / Running Total In depth throughout the Portal. Further, If you can attach the PBIX file, it will enable analyst’s to help you quicker, as well as re-reading through your first post and clearly defining your question.
In the mean time here are some links help you get started on running totals.
Cumulative Totals Only Up To Specific Dates - DAX Tutorial For Power BI
https://portal.enterprisedna.co/courses/313969/lectures/6727109
Cheers Adam
Hi @Jeffb, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
- Use the forum search to discover if your query has been asked before by another member.
- When posting a topic with formula make sure that it is correctly formatted to preformatted text </>.
- Use the proper category that best describes your topic
- Provide as much context to a question as possible.
- Include the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi @Jeffb,
Few things to note.
- I’ve marked your Date table as date table
- You don’t have a Product dimension table, instead you’ve used the OHB table as a dimension
See if this meets your requirement.
OHB =
VAR FirstDay = MINX( ALLSELECTED( 'Date Table'[Date] ), [Date] )
VAR OH =
CALCULATE( SUM( 'On Hand Balance'[On hand balance] ),
DATESBETWEEN( 'Date Table'[Date],
FirstDay,
MAX( 'Date Table'[Date] )
VAR Supply =
CALCULATE( [Manufacture],
FirstDay,
VAR Demand =
CALCULATE( [Sales],
FirstDay,
IF( NOT( ISBLANK( CALCULATE([Manufacture] + [Rolling OHB] + [Sales] , ALLSELECTED( 'On Hand Balance'[Item number] )) )),
OH + Supply - Demand
With this result.
Here’s your sample file. On Hand Balance.pbix (149.0 KB)
I hope this is helpful.
Hi Melissa
You are an absolute star. I really appreciate your support and guidance. Just what I wanted.
Regards
Jeff
