I think I know the answer, but I just want to confirm… Is it possible to omit a field from the standard tooltip (without resorting to tooltip report pages)? For example, if my chart shows Series A and Series B as a line chart, can I configure the tooltip to only show the value for Series A?
@DaveC No, you can’t. ALternatively, you can create a nother page as a tool and configure to show only Series A.
Let me know if that works. Thanks
Thanks. I have used tooltip report pages several times in the past. I was trying to avoid doing that because, in my experience, the report page tooltips always experience a bit of a delay in appearing, but if that’s the only way to do it, I guess I will have to.
Thanks!
