Hi all,
Need your help in my new case issue. I would like to use offset in Calendar table. The reason is to filter easily the last completed (year/month/week) from my sales data table. Sourced around youtube and came across a calendar table with offset (Year/Month/Week) from youtuber AviSingh.
Is there a way to integrate the offset function into Sam’s calendar table?
Attached is the source file that I am using (my fail attempt) Calendar PBI.pbix (170.9 KB)
I came across this blog post yesterday on dynamically identifying completed sales months. Not exactly the same offset method you mentioned, but a very straightforward approach that seems like it could get you to the same outcome.
