I am wanting to calculate a % of total for specific categories and add them as a separate category to the table.
i.e.- 60% of the Christmas Category. What would be the calculation
Hello @bsteinacher,
Thank you for posting your query onto the Forum.
You can use the formula as mentioned below -
% of Total =
VAR CategoryTotal = SUMX(
ALL( Products[Product Name] ) ,
CALCULATE( [Total Sales] ) )
DIVIDE( [Total Sales] , CategoryTotal , 0 )
Hoping you find this useful and helps you to achieve the desired analysis.
Please Note: The naming conventions may differ so accordingly use it in your file.
Thanks & Warm Regards,
Harsh
HI @bsteinacher, did the response/training content provided by @user help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
