ODBC connection error
I am trying to connect to an Access database but keep getting this error:
Orders
ODBC: ERROR [HY000] [Microsoft][ODBC Microsoft Access Driver] The database has been placed in a state by an unknown user that prevents it from being opened or locked. ERROR [IM006] [Microsoft][ODBC Driver Manager] Driver’s SQLSetConnectAttr failed ERROR [HY000] [Microsoft][ODBC Microsoft Access Driver] The database has been placed in a state by an unknown user that prevents it from being opened or locked.
Does anyone know how to correct this?
HI @michael.wescott7226
You likely need to save the access data base in a folder where everyone has access to the access database.
Using DataMentor tool built within the EDNA Platfor, this what comes up:
Possible Solutions for ODBC Error with Microsoft Access
If you’re encountering the error:
You can try the following steps to resolve the issue:
  1. Check for Existing Connections:
  • Make sure no other users or applications are currently using the database. Close any open connections.
  1. Compact and Repair the Database:
  • Open Microsoft Access and use the Compact and Repair Database feature:
    • Open Access without opening the database.
    • Go to Database Tools > Compact and Repair Database.
  1. Check Database Permissions:
  • Ensure that you have the necessary permissions to access the database. You may need to adjust the file permissions.
  1. Enable Exclusive Access:
  • If possible, try to open the database in exclusive mode. This may help avoid conflicts with other users or applications.
  1. Create a Backup:
  • Always create a backup of your database before performing any repair attempts.
  1. Convert the Database:
  • If using an older database format (e.g., .mdb), consider converting it to the latest format (.accdb) using Access.
  1. Check for Access/ODBC Driver Updates:
  • Ensure that the ODBC driver for Access is up to date. Check for updates on Microsoft’s website.
  1. Recreate the ODBC Data Source:
  • If you are using a DSN, recreate it to ensure there are no configuration issues.
  1. Check for Corruption:
  • If the database is corrupted, you may need to restore it from a backup or use data recovery tools.
By following these steps, you should be able to address the error and regain access to your Access database
Please give DataMentor a try in solving your issues. DataMentor is a great tool.
Keith
Hi @michael.wescott7226 ,
Welcome back to Forum.
You can also check PowerBI data source prerequisits :
Good luck.
