Hi All,
I have checked most of questions related to Incorrect totals in the forum and applied the steps to solve this. But i am not able to come out with a solution. Hence, i am posting this here. Hope anyone from the forum might have come across this scenario.
please drop pbix
Hi @nbaraili
I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
- A clear explanation of the problem you are experiencing
- A mockup of the results you want to achieve
- Your current work-in-progress PBIX file
- Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Thank you!
Hello @nbaraili
We notice that no response was received from you on the post above.
We are waiting for your masked demo pbix file and other supporting links and details so other users can help you in your query.
Due to your inactivity, we’ll be tagging this post as Solved.
Should you wish to add your masked demo pbix file and other supporting links and details, you can reopen this thread.
Thank you!
Sorry for the delay. I was travelling and not able look into this.
In the below image, Column E is the multiplication of Column C and D and Column F is (B/E). Column C is constant and Column D is calculated based on latest date. Though i wrote a formula to achieve this in power bi, I am not getting the correct result. For your reference, I have attached the pbix file.
FTE Calculation.pbix (394.6 KB)
@nbaraili please see the below solution along with the file.
Let me know if that works for you. Thanks
Solved - FTE Calculation.pbix (394.7 KB)
Hi @nbaraili
Thank you
Hi Mohammed,
Thank you for writing back. Column C is calculated based on the country and for India it’s 45, China 40 and so on. I have attached the screenshot for your reference.
Thanks,
@nbaraili As per your description above, Result is based on YTD Standard hours / FTE_Hours which is giving correct result as 1,268.42
Please elaborate on the problem in detail as to what exactly you are looking for. Thanks
Hi @nbaraili,
We’ve noticed that no response was received from you on the post above.
Just following up if you still require assistance to solve your inquiry.
Hi @nbaraili
We noticed that your inquiry was left unsolved for quite some time now.
Looks like your inquiry was out of the experts’ and users’ bounds.
If you were sure you provided all pertinent context to your concerns and read how to use the forum more effectively and still find your question unanswered, your membership also comes with relevant resources that may help you with your Power BI education, so we advise that you check these resources as well.
