Friends, i am facing a difficulty in applying conditional formatting to change color for data label in a column chart. Although same is working quite well while applying conditional formatting on column colors. I dont know may be i am missing a trick. I experimented with all using gradient, rule and field but none is working as desired.
Suppose i want to change data label color as per sales amount or as per a category.
It will be grateful if any one can spare his/her precious time to help.
LABEL FONT.pbix (673.9 KB)
Thanks and regards
Before you send your question.
Make sure that all details relevant to your question is complete:
- Your current work-in-progress PBIX file - VERY IMPORTANT
- A clear explanation of the problem you are experiencing
- A mockup of the results you want to achieve
- Your underlying data file
Also make sure that your data file contains no confidential information. If it does, click the link above.
*** DELETE THIS MESSAGE IF YOU ARE SURE ALL YOUR DETAILS ARE COMPLETE OR IF THE ABOVE INFORMATION IS NOT APPLICABLE TO YOUR QUESTION.***
