Hi Support
When I went to Custom Functions in Power Query under Learning Center/Labs, there should have two videos but when I clicked on both of them, they are no video and black screen. Maybe these are not being uploaded. I hope these will be uploaded soon. Thanks.
Cindy
Hi @CindyC, thanks for reaching out.
We checked the videos that you mentioned above and they are working from our end. Could it possibly be an internet connection issue or a network error? Please try accessing other videos if they are also the same.
https://share.vidyard.com/watch/hHPG7Hk1bw3UyUM8RTU9wY?
Looking forward to your update.
Hi @CindyC, if the issue has been resolved kindly mark this post as solved.
Hi @CindyC, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
