No Blank rows when there is no Child Hierarchy in Matrix
Hello All,
     I have Multiple Hierarchies. For few we have Dimension at every level in Hierarchy. For few Some Low Hierarchy is Blank.
If the Low Hierarchy is Blank ,I don’t want to see the Blank row.
I implemented the solution using ISINSCOPE DAX for 2 Hierarchies, If there were more than How to do that??
Measure =
IF(ISINSCOPE(‘Table’[Hier1]),
IF(ISINSCOPE(‘Table’[Hier2]),
IF(MAX(‘Table’[Hier2])=BLANK(),BLANK(),SUM([value])) ,
SUM([value])),
SUM([value]))
How to achieve this scenario?
TIA
Bumping this post for more visibility from our experts and users.
If you don’t want to see blanks in [Hier2] column then select your Matrix visual and go to filters pane and under [Hier2] column Basic Filtering just enable Select All option and deselect (Blanks) option as shown in the image below.
Hi @likhitha - You can refer to below post and also can search on Ragged Heirarchies and how to handle them.
Regards,
Ankit J
Hello @likhitha
Thank you
Hi @likhitha
Due to inactivity, a response on this post has been tagged as “Solution”.
I got the solution with the following DAX
Sales =
SWITCH(TRUE(),
ISINSCOPE(Sheet1[Hie 4])&&SELECTEDVALUE(Sheet1[Hie 4])=BLANK(),BLANK(),
ISINSCOPE(Sheet1[Hie 3])&&SELECTEDVALUE(Sheet1[Hie 3])=BLANK(),BLANK(),
ISINSCOPE(Sheet1[Hie 2])&&SELECTEDVALUE(Sheet1[Hie 2])=BLANK(),BLANK(),
ISINSCOPE(Sheet1[Hie 1])&&SELECTEDVALUE(Sheet1[Hie 1])=BLANK(),BLANK(),SUM(Sheet1[Sales]))
Thanks for the reply.
With Regards,
Likhitha
