Hi All,
I’m trying to create calculated measure based on existing measures when they are empty or zero.
I’m trying below dax code but still having issues as in the file i have highlighted in column E where row 5 & 30 is not picking right values.Can someone help me with the dax?
Sample data.xlsx (14.4 KB)
var __measure1blank=if(or(ISBLANK(__measure1),__measure1=0),0,__measure1)
var __measure2blank=if(or(ISBLANK(__measure2),__measure2=0),0,__measure2)
var __measure3blank=if(or(ISBLANK(__measure3),__measure3=0),0,__measure3)
Return
if(__measure1=0,__measure2,if ((__measure1blank+__measure2blank)=0.00,__measure3,__measure1))
TIA.
Harsh
May 31, 2022, 2:43pm
2
Hello @Ravi85 ,
Is this the result you’re looking for? Below is the screenshot provided for the reference -
To achieve this result, below is the DAX Measure provided for the reference -
Calculated Measure =
VAR _Results_For_Measure_3 =
( ISBLANK( SELECTEDVALUE( Data[Measure1] ) ) || SELECTEDVALUE( Data[Measure1] ) = 0 ) &&
( ISBLANK( SELECTEDVALUE( Data[Measure2] ) ) || SELECTEDVALUE( Data[Measure2] ) = 0 )
VAR _Results_For_Measure_2 =
VAR _Results_For_Measure_1 =
NOT ISBLANK( SELECTEDVALUE( Data[Measure1] ) ) || SELECTEDVALUE( Data[Measure1] ) <> 0
SWITCH( TRUE() ,
_Results_For_Measure_3 , SELECTEDVALUE( Data[measure3] ) ,
_Results_For_Measure_2 , SELECTEDVALUE( Data[measure2] ) ,
_Results_For_Measure_1 , SELECTEDVALUE( Data[Measure1] ) ,
Thanks and Warm Regards,
Harsh
Nested IF Measure - Harsh.pbix (20.9 KB)
Thanks @Harsh ,
i also managed using nested if statements.
return
if(__measure1blank=0,if(__measure2blank=0,__measure3blank,__measure2blank),__measure1blank)
Hi @Harsh ,
can i check why the totals are not displaying correct for calculated measure?
TIA.
Harsh
June 1, 2022, 9:33am
5
Hello @Ravi85 ,
Yesterday, I addressed the very same issue onto the Forum. In order to fix the totals, you can write an additional measure which fixes the results for grand totals as well.
One of our EDNA expert had already created a post on it pertaining to the topic - “How To Fix Incorrect Totals ”.
Below are the links of the post provided for the reference.
Harsh
That’s fantastic thanks Harsh.
As my actual problem was a bit more complex I ended up looking at one of the other posts and using the sumx - values and addcolumns to get the max of either amounts and then doing a cumulative total on that.
All solved in the end, thanks again.
When using a measure column in a visual, it is not uncommon in Power BI to find that the totals are incorrect. The Fix Incorrect Totals DAX pattern can be used to correct this issue.
When a DAX measure is providing the correct detail value it often, unfortunately, provides an incorrect value for the total row. This is due to there being no evaluation context for the total row. For example, when comparing the [Total Sales] to the [Sales LY] to find the minimum for a customer using the simple DAX…
