I have the following query in M and wanted to know where my syntax issue is wrong:
Original Source = each if [#“Original Source Drill-Down 1”] = “IMPORT”
then “Events” , else if [#“Original Source Drill-Down 1”] = “Salesforce” then “Salesforce”, else [Original Source v.1])
You’ve inserted the symbol of “,” in your M code remove them and write it like this -
then “Events” else if [#“Original Source Drill-Down 1”] = “Salesforce” then “Salesforce” else [Original Source v.1])
Once you remove the comma (",") the code should work.
