Need help with sales in first 7 days
Hello,
I can calculate the sales in first 7 days, following the dax formula like this:
However, when I want to see which is the product during this first 7 days of each customer, I have to select both customer name and the sales day during first 7 days → to return the name of the product
Could anyone help me with dax formula that allow me to get the product name in first 7 days when I click on each customer name only (& does not have to choose the date in the table 2)
0. Practice DAX Mastering 2A.pbix (450.7 KB)
Thanks in advanced
@hunghahuy 0. Practice DAX Mastering 2A.pbix (481.1 KB)
Total Transaction in First 7 Day Ant =
VAR First_Date =
    CALCULATE (
        MIN ( 'Sales Orders'[OrderDate] ),
        REMOVEFILTERS ( Products )
VAR FirstDates =
    FILTER (
        Dates,
        Dates[Date] >= First_Date
            &&  Dates[Date] <= First_Date + 7
VAR Result =
    CALCULATE (
        COUNTROWS ( Products ),
        KEEPFILTERS (
            CALCULATETABLE (
                DISTINCT ( Products[Product Index] ),
                FirstDates,
                CROSSFILTER ( 'Sales Orders'[Product Index], 'Products'[Product Index], BOTH )
    Result
Hello @hunghahuy,
While my colleague @AntrikshSharma has already posted a solution, I just wanted to share my solution.
I’ve worked it in couple of ways i.e., one solution is in the form of “Total Transactions In First 7 Days (In Terms of Products Count)” whereas the other one is in the form of “Total Transactions In First 7 Days (In Terms of Products Names)”. Below are both the DAX measures alongwith the screenshot of the final results provided for the reference -
Products In First 7 Days - Product Count =
SUMX(
    ADDCOLUMNS(
        FILTER(
            SUMMARIZE(
                'Sales Orders' ,
                'Sales Orders'[OrderDate] ,
                Dates[Date] ,
                Customers[Customer Names] ,
                Products[Product Name] ) ,
            Dates[Date] >=
                CALCULATE( MIN( 'Sales Orders'[OrderDate] ) ,
                    ALLEXCEPT( 'Sales Orders' , Customers[Customer Names] ) ) &&
            Dates[Date] <=
                    ALLEXCEPT( 'Sales Orders' , Customers[Customer Names] ) ) + 7 ) ,
        "@Product_Name" ,
        1 ) ,
    [@Product_Name] )
Products In First 7 Days - Product Names =
IF( ISINSCOPE( Customers[Customer Names] ) ,
    CONCATENATEX(
        TOPN(
            15 ,
            ADDCOLUMNS(
                FILTER(
                    SUMMARIZE(
                        'Sales Orders' ,
                        Dates[Date] ,
                    VAR _Min_Date =
                    Dates[Date] >= _Min_Date &&
                    Dates[Date] <= _Min_Date + 7 ) ,
                "@Product_Name" ,
                CALCULATE( MIN( Products[Product Name] ) ) ) ,
            [@Product_Name] ,
            ASC ) ,
        Products[Product Name] ,
    BLANK() )
Hoping you find this helpful.
Important Note: In your case, the figure for “Total Transactions for First 7 Days” is showcasing as 67 whereas the actual number of records for those transactions is 104.
Thanks and Warm Regards,
Harsh
Total Transactions In First 7 Days - Harsh.pbix (454.5 KB)
Thank you @AntrikshSharma
Thank you @Harsh
But I wonder why the total in the second table (that has Product in first 7 Days - Product Counts) is different from the total in my measure “Total Transaction in First 7 Days”
Did I get the total wrong? Please correct me
Thank you
Hello @hunghahuy,
Yes, the total in the measure - “Total Transaction in First 7 Days” is incorrect because even if, you export the data to cross-verify and take a sum of that column then the total will be 104 and not 67.
The reason why, you’re seeing the total as 67 is because at a grand total level there’s no context transferred and therefore, it took the First Date at an overall level i.e., 14-Aug-2019 and added 7 days to it. So it created a range from 14-Aug-2019 to 21-Aug-2019.
To cross-check the above explanation, go to the “Sales Orders” table and select the range from 14-Aug-2019 to 21-Aug-2019 and you’ll see 67 rows of data being filtered. Below is the screenshot provided for the reference -
In case, you would like to learn more about fixing totals. Below is the link of the post provided for the reference pertaining to the topic - “Fix Incorrect Totals”.
Harsh
Thank you so much @Harsh
Now I understand my mistake
Thanks for your help
Best Regards
Hung
Hello @hunghahuy,
You’re Welcome!
We’re glad that we were able to assist you.
Harsh
