Navigation menu
Another problem i am facing in navigation menu that the total that i am displaying is changing the moment i do “CTRL + click” to navigate on another page.
For example if you based on attached screenshot Home Page is showing correct total values for Count A & B. After i do “CTRL + click” on Total Count page the all values changes to inital Total value which is 250. this change happens in Home page & also on Total Count page. I am trying to figuring that out what might be causing?
Any help is greatly appreciated.
FYI …https://powerbi.tips/product/layouts-sunset/
Is this a repeat of the other question?
I started from the scratch & was able to fix problem. its tricky if you are not careful enough with card & bookmarks. Thanks for your reply.
Ok great.
