Hey guys,
I hope this is the right place to try to solve this issue.
One of my gateway connectors is MySQL and suddenly (don’t know if it was when i’ve update the gateway or not) that connection stop working. Couldn’t refresh my data. Always same error. My IP address was blocked because of many connection errors. unblock with mysqladmin flush-hosts
The guy responsible with that server told me that he couldn’t do anything else.
I’m asking you guys: has this already happened with any of you? What happened? What did you do?
Thanks a lot
Pedro
Hi @pedroccamara, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
