My first dashboard
Hi all, I am trying to set up a bed occupancy dashboard by days, facility, and type of resident. I loaded in Power BI the budget for the year. I have to calculate the % occupancy and when I am calculated the available bed days by type -permanent and respite resident, I get the same amount of days …The formula I used as per below:
Kindly let me know, if the formula looks ok.I can send the data sample if need it.
Bed allocation Permanent =
CALCULATE([Available beds Now],
‘Actual beds available by facili’[Bed Allocation by Facility]=“Permanent”)
Hi @Victoria ctoria,
You need to use FILTER: CALCULATE([Available beds Now], FILTER(
‘Actual beds available by facili’[Bed Allocation by Facility]=“Permanent”))
have fun, Jose Milhazes
Hi Jose, Thank you, for some reason, it didn’t work but I found a variable formula that did the job.
Regards,
