Hi all,
I am going through the Tabular Editor course by @AntrikshSharma now and excellent so far but was wondering if this issue is covered, if so, disregard.
I created a Dax function to fix the total for a matrix and trying to use Tabular editor so that I don’t have to rewrite for every single measure.
The way it is currently structure, I have to write separate Dax for each table Is there no way around this or am I doing it correctly? Please see image below.
Thank you in advance.
Hi @ysherriff, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
- Use the forum search to discover if your query has been asked before by another member.
- When posting a topic with formula make sure that it is correctly formatted to preformatted text </>.
