Unless I am missing something is there a way to see multiple dimensions on the x-axis of a bar chart similar to the attachment below. I know that you can use put multiple dimension on the bar chart and then go down the hierarchy but I want to see it.
@mbraun You can do this by placing multiple categories on X-Axis then clicking on Expand all down one level in the hierarchy . In the format pane, Go to X-Axis and turn off the Concatenate Labels. You will get the result as follow:
Thanks.
