I am new to Deneb Viz and trying to figure out how to show data lables of budget and actuals both in bar graph… Where to turn on / off the data labels of bars
DENEB-WORKING.pbix (2.6 MB)
Hi @amarhasnani.
There is no data label on\off for bar marks (or any mark, for that matter) in Deneb\Vega-Lite. To show data labels you’ll need to add additional text mark objects to your code. (In your case, in the same layer block as your 2 existing bar marks.)
An example of layer block containing both bar and text marks was presented in a previous Deneb Showcase thread and may be of interest.
Hope it helps.
Thank you Greg, I tried adding 2 mark to the layer but seems the value are overalaping in category … any way to fix data lables?
Hi @amarhasnani. Unfortunately, I’m not able to determine a cause from your screenshot, but can only guess that you’re perhaps showing all data values in the top visual and aggregated values in the bottom visual. If you’d like further investigation, please upload a PBIX file and a screenshot marked-up with your desired outcome.
Hope it helps.
Hello @amarhasnani
Thank you
Hi @amarhasnani
Due to inactivity, we’d like to conclude that you no longer require assistance to solve your inquiry.
