Multiple column headings in matrix
HI
I am trying to recreate the following format
currently struggling to add multiple header rows , i.e. want the orchard << block << area.
any suggestions
thanks
Hi @farmboy. If you want multiple pieces of data in the same matrix column header, try concatenating the values and use UNICHAR( 10 ) as the delimiter to force a newline.
Hope it helps.
Hi @farmboy, did the response provided by @Greg help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @farmboy, we’ve noticed that no response has been received from you since the 21st of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @farmboy, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
