Hi, I want to create a multilingual dashboard. My intention was that the slicer title and the content below would automatically change according to the language version I selected. However, my actual dashboard involves a much larger dataset and is not manually input. I don’t want to manually translate each word. Is there any better solution to achieve my goal? Thanks!
Hi @AmyX ,
If you are familiar with Python maybe you can check Gaelim’s interesting video
How To Translate Texts Using Python For Power BI
