MTD Value is showing Blank in Card
If i use the below measure in a table with Year or Month or Week, i can see the values, but if i use this in Card it’s shows blank.
Could you please highlight what am i missing ?
MTD Hours =
ShowValueForDates =
VAR LastDateWithData=
MAX(data[Period Ending Date]),
REMOVEFILTERS()
VAR FirstDateVisible=
MIN(Dates[Calendar Dates])
VAR Result=
FirstDateVisible<=LastDateWithData
Return
Result
IF(
[ShowValueForDates],
VAR LastDayAvailable=MAX(Dates[Day of Fiscal Month Number])
VAR LastFiscalYearMonthAvailable=MAX(Dates[FY Year Month Number])
VAR Hours=
[Charged Hours],
ALLEXCEPT(Dates,Dates[Day of week]),
Dates[Day of Fiscal Month Number]<=LastDayAvailable,
Dates[FY Year Month Number]=LastFiscalYearMonthAvailable)
Return
Hours
Screenshot
@nbaraili ,
Unlike tables or matrixes, card visuals have no implicit context. You need to build that up using virtual tables. This video demonstrates exactly how to do that.
– Brian
Hello Brian,
Thank you for your reply.
I will let you know whether I am able to find a solution.
Regards,
Niraj
@nbaraili ,
Great – give it a go, and if you still have questions or problems just let me know.
Hi @nbaraili, we’ve noticed that no response has been received from you since September 15.
Hi @nbaraili, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please create a new thread.
