@AliB,
Since there are holes in your date where there no, looks like, calls. You’d be hard pressed to use the built-in time intelligence.
I think the following will work, or might need small tweaks:
Moving Average not Counting Zero=
VAR __MovingAvgLength= 7
VAR __CurrentDate= MAX( DATETABLE[DATECOLUMN])
IF(
COUNT( DATETABLE[DATECOLUMN]) >= __MovingAvgLength, //Make sure there are enough dates to produce an average
DIVIDE(
[MEASURE],
/*Here you are using your sales table as a filter for date
so only get the dates for which there are sales */
COUNT (DATETABLE[DATECOLUMN]),
FactTable
FILTER(
ALL( DATETABLE[DATECOLUMN]),
DATETABLE[DATECOLUMN] >= ( __CurrentDate - __MovingAvgLength)
DATETABLE[DATECOLUMN] <= __CurrentDate
I have a date table so I believe inbuilt time intelligence should work. the averages weren’t working correctly because it didn’t take any notice of days without a value but adding the +0 to the formula appears to work ie it replaces blank with 0
Is it a simpler / inbuilt shortcut for Sam’s IF(ISBLANK([measure],0) or some little quirk in the language that may get fixed therefore should I switch to the IF statement mentioned as a safer solution …
@AliB,
I misread your original request. Instead of ignoring blank days ( which is what my function would do you) you should use sam’s formula where it checks to see if the measure is blank and if that is true return a 0. It’s not a quirk of DAX, it’s just the way DAX handles blank values. Blanks <> 0, which is why you to have to explicitly define blanks= 0
